p0455
Buck Sr
Ohio
I need some help please with my 07 cobalt 2.2 liter, with a check engine light and code po 455. after deleting the code I installed a new dealership gas cap, and a purge valve solenoid from auto zone and the light still comes.
I would appreciate any input.
I am 62 and still trying to learn about these newer type cars!!!!!
Thank you
jeffsPSEMadness
Rochester
Thank you
Yeah I'm getting the same code and did the same fixes well purge solenoid I did waiting for the gas cap. If it still come on after that. The next thing will. Ring to have a smoke test done. Also check all of your evap lines and make sure not cracked and check your filler tube too. You never know
Buck Sr
Ohio
thanks
The other possibility is a bad fuel tank pressure sensor. It's on the side of the EVAP canister.
Buck Sr
Ohio
Thanks yello eye. Today my info center showed to check gas cap. I put a brand new one on a month ago. Now what do I do? Is this a process of elimination? I hate to keep buying parts if its not the problem. Should I get a smoke test?
thanks
Buck Sr
Ohio
Thank you yelloeye. Can you tell me where the evap canister is located so I can find the fuel tank pressure sensor?
I would really appreciate it.
jeffsPSEMadness
Rochester
It's the black box looking thing by your gas tank with the plastic lines.
Buck Sr
Ohio
Thank you so much Jeff.
I thought I would have to drop the fuel tank and the info sure helps.
