seafoam problem
BlackCobalt707
Dover AFB, Delaware
i seafoamed my car and now the car is having a hard time starting. i think i put a little too much. anyone know how to fix that problem?
where did u put it? what was the process you used? need more info then "i put it in my car now it's not working"
BlackCobalt707
Dover AFB, Delaware
vacuum line. right above the throttle body
---------- Post added at 04:02 PM ---------- Previous post was at 03:28 PM ----------
we can end the thread, i got the car started
xxxxsh4d0wxxxx
hope you change the oil
Let me start by saying, you, Tuner, are completely wrong.
Second off, how would sucking ANYTHING into a vacuum line even begin have any effect on the oil? If you suck seafoam into your vacuum line and it gets into your oil, you have a bigger problem than seafoaming your car.
Also, I am not trying to be a dick, and I am sorry if it comes off like that.
xxxxsh4d0wxxxx
um...blowby? it'll get in there.
No. You do not change your oil after sucking seafoam into the vacuum line. That is absolutely unnecessary and uncalled for.
Like I said, if your seafoam is mixing with the oil when sucking it into a vacuum line, you have bigger problems.
And blow-by = worn piston rings = bigger problem.
Thanks.
