Traction and brake problems
Ramphex
Poconos, PA/North Jersey
So lately I've been having a couple of problems... brake pedal is often STIFF and once I give my foot some more power to press it, ABS kicks in and car stops hard.... Never did that before and it's kind of annoying now... second problem is, in second gear after like 2800-3000RPM I lose traction and tires just start spinning and the car starts sliding to the side, that's on a clean road (no rocks/snow/ice) with 1 month old winter tires with a lot of tread still... so any ideas?
1WhiteSSTC
Banned
The Great White North
i'll start with the tires, ever driven with winter tires before on your cobalt? They don't give very good traction at all on dry roads, maybe your used to going into 2nd and dropping the hammer? With winter tires they'll break loose very easy.
The brakes......have you checked all your rotors/pads? Clear surface? Have you bled your brakes anytime recently?
Ramphex
Haven't bled the brakes but rotors and pads are like 2 months old and still have plenty of metal on both, rotors aren't warped or anything
1WhiteSSTC
Banned
I would bleed the brakes and see how it feels after.
Are you satisfied with my explanation for the winter tires or do you think I'm wrong?
your wheel cylinders could be leaking contaminating the shoes and causing cracks, maybe a piece of the shoe lining broke free and is stuck. i've seen that happen ONCE. it's unlikely though. all I can say is do a visual inspection. have you ever removed drums before?
Ramphex
I haven't removed them on this car, my old car yeah but when I went for inspection they said my drums were still great so I never bothered replacing anything with them
jmarie
Maryland
enough air in your tires? my car did this when i didnt have enough air.. freaked me the **** out but it was a little more drastic...
Tom
Houston TX
Your brake booster may be malfunctioning
or
Worn pads
or
1 or more caliper or wheel cylinder pistons have seized or sticking
or if you have recently replaced the pads,and they have not set in yet...
Mintyman01
Op break problems
I heard most cars adjust the drums when driving in reverse or in park. I've heard of this problem with cobalts when the hand brake isn't used regularly because chevy cobalt adjust the drums when it's parked and the hand brake is applied. Just something I heard from a chevy tech. May or may not be the reason though.
8balt
