15 inch rims lame?
They call me godly
Glen Fork, WV
The only thing I ever went lower then 18's on was my Tercel, and that was 15" steelies with radials :D If your going for looks on a sports car I see 18's being the best
dont make the mistake i made, you dont want 15" rims...
205/60/15 just like stock, well wider than stock, but same height
205/45/17
also mine is lowered 2"f/2.5"r so if your still stock height, it will look even worse with 15's...
outtamymind
Calgary, Alberta
i find the 215/45r17's to be a good tire for the cobalts that are just more or less dd's with some fun in between.
423
Kilmarnock, VA (USA)
While you are getting current use from your 15's,,,, shop for 17's you really like. Go 205/50/17 tires. These are the same overall height as the factory 15's although the 17's are lower profile. Speedo will not be effected at all. Direct swap, no issues.
Make sure you want to hold on to the car a while before you invest money of that nature.
423
