2.2L/2.4L MAF Sensor block off plate???
PsychoCam
Does any company make a plate that can block off the maf sensor. I want to relocate it by using the zzp pipe that I have but I do not want to cut my garret ic piping so I just want to block off the maf spot I have not and not weld it shut
Thanks ccf
PsychoCam
Never even thought of that. Good thinking. I will start fabing one up hopefully soon. Thank you for the advice!
How is ur turbo kit?
I am bored of 10 psi lol
I need to build my motor
how goes it!
i would do the same as what was already stated :p
you could also modify a dummy plug to sit in there if wanted or if it is in a metal pipe you could grind it off and have it welded shut...that would be best for flow. you will cause a small (probly un noticable) amount of turbulance with jsut a plug on there
