An Idea
Aredtear
Spruce Grove Alberta Canada
Ok so this isn't a build but I read some guys talking about this on g5club.net and was thinking of doing it myself (after my warrenty runs out)
So the conversation started with a guy thinking of doing an LS swap (most likely saw it from Forza) And some people figured it couldn't happen and what not. Their was then mention of doing a V6 swap and that's what struck my intrest. So that's what I'm seriously thinking of doing and s/c'ing it or t/cing it.
So my only questions are is this possible? and what would I have to do to make it fit and stuff? I'm gonna guess the stock mounts wouldn't do so I'm probably gonna have to look into swapping it with mounts off a G6.
Let me know what yall think. Good Idea? Bad Idea? And if you know if it's been done could anyone let me know how they did it? Thanx Guys :grd:
I'm asking this on here cause their are a few people on g5club that just like to shit on people and their ideas :893Chainsaw-Smilie-:shooter:
id have to look i cant either
---------- Post added at 12:17 AM ---------- Previous post was at 12:16 AM ----------
2009 Pontiac G6 GXP Sedan Performance & Efficiency Standard Features
- 3,564 cc 3.6 liters V 6 front engine with 94.0 mm bore, 85.6 mm stroke, 10.2 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder LY7
- Unleaded fuel 87
- Multi-point injection fuel system
- 16.4 gallon main unleaded fuel tank 13.7
- Power: 188 kW , 252 HP SAE @ 6,300 rpm; 251 ft lb , 340 Nm @ 3,200 rpm
2009 Pontiac G6 GXP Sedan Handling, Ride & Braking Standard Features
- ABS
- Four disc brakes including two ventilated discs
- Electronic traction control via ABS & engine management
- Immobilizer
- Spacesaver steel rim spare wheel
- Stability control
- Strut front suspension independent with stabilizer bar and coil springs, multi-link rear suspension independent with stabilizer bar and coil springs
2009 Pontiac G6 GXP Sedan Exterior & Aerodynamics Standard Features
- Painted front and rear bumpers
- Day time running lights
- Driver and passenger power painted door mirrors
- External dimensions: overall length (inches): 189.0, overall width (inches): 70.6, overall height (inches): 57.1, wheelbase (inches): 112.3, front track (inches): 59.6, rear track (inches): 60.0 and curb to curb turning circle (feet): 40.0
- Front fog lights
- Complex surface lens halogen bulb headlights
- Luxury trim alloy & leather on gearknob and alloy look on doors
- Metallic paint
- Fixed rear window with defogger
- Trunk/hatch spoiler
- Weights: curb weight (lbs) 3,545
- Windshield wipers with automatic intermittent wipe
---------- Post added at 12:17 AM ---------- Previous post was at 12:17 AM ----------
increase the bores and s/c it??? with the reduced weight of the cobalt???
fully built internals with polished and ported headers/TB/supercharger, intake manifold/ dual pass/ optionb/ stock heat exchanger plus a cobra HE... meth injections...etc.etc must haves
sloancallaway
not worth in man... just turbocharge... supercharge or buy somehting faster... you especially dont want to get into that unless yout are confident you can do it all yourself
Aredtear
I dunno. I think the only hard part would be getting a new Wiring harness for the V6 and re-wiring everything. All the mechanical stuff could be pretty easy plus it helps when you know some people with their own shops and stuff that can lend a hand. I still have like 3 years of thinking and planning cause I'm not gonna do anything until my warrenty runs out
Tom
Houston TX
ill say the same thing that i said on g5club.net...
If your oprah rich anything is possible....
Just turbo your ride ;)
Aredtear
Haha alright then, just thought it could be a build cause I COULD possibly do it. I was also searching the other day and came across a guy who had done this to his 05 G5..... but the site I found it was kinda shady so I dunno weather to believe it or not. SO yeah I dunno
8balt
