Feb 13, 2011 #1 M michelsl Member Joined Feb 13, 2011 Posts 36 Reaction score 0 Location IL The head lights are coming on and off as they please and was wondering if any one could shed some light on this issue for me. Thanks
Feb 13, 2011 #2 cobalt123 Platinum Member Joined Jul 18, 2009 Posts 15,200 Reaction score 4 Location Tyler Texas the male/female connector, the blue ones, are probably loose. check them if so take some thick gauge wire and stick it in between the two
Feb 13, 2011 #3 D darklink991 Full Access Member Joined Jan 8, 2011 Posts 65 Reaction score 0 Location pocatello So for 05 cobalt how would you hook up halos to be on during the day. Someone told me brown and black from the side marker, but arnt those the little ones behind the orange side marker.
Feb 13, 2011 #4 cobalt123 Platinum Member Joined Jul 18, 2009 Posts 15,200 Reaction score 4 Location Tyler Texas just figure out which wire is for the running lights, on the cobalt they are always on. i dont remeber which one it is
Feb 13, 2011 #5 M michelsl Member Joined Feb 13, 2011 Posts 36 Reaction score 0 Location IL cobalt123 said: the male/female connector, the blue ones, are probably loose. check them if so take some thick gauge wire and stick it in between the two Click to expand... the lights are coming on when they dont need to is the problem not that they just go out its like the sensor is bad.
Feb 13, 2011 #6 D darklink991 Full Access Member Joined Jan 8, 2011 Posts 65 Reaction score 0 Location pocatello Could it be your switch on your steering wheel.
Feb 13, 2011 #7 cobalt123 Platinum Member Joined Jul 18, 2009 Posts 15,200 Reaction score 4 Location Tyler Texas the lights come on automatically
Feb 13, 2011 #8 M michelsl Member Joined Feb 13, 2011 Posts 36 Reaction score 0 Location IL it has the automatic lights but you can manually overide them and they still come on. does anyone no where the sensor is located
Feb 13, 2011 #9 cobalt123 Platinum Member Joined Jul 18, 2009 Posts 15,200 Reaction score 4 Location Tyler Texas im not sure if your still under warranty i would just take it to the dealer. that sensor might be in the BCM/PCM
Feb 13, 2011 #10 D darklink991 Full Access Member Joined Jan 8, 2011 Posts 65 Reaction score 0 Location pocatello I will just say good luck.
