Craziest thing..
The craziest thing happened today. So little back ground. I installed some subs monday night, all that night the system worked perfectly. tuesday the system worked perfectly. this morning when i drove to work the system worked perfectly. I was getting ready to leave work to go get breakfast and I started my car... a couple warnings flashed on the DIC and the dinger went ballistic. all that i remember that came on: service airbag, esc off, service traction, ice possble, headlights off. so i figured maybe it was a bad start or something stupid like that. I turned off the the ignition and removed the key... engine remained running for about 10-15 secounds... WTF! i did this about 10 times same result then i shut it off and unplugged the remote wire of my amp which is ran to the fuse for the windshield wipers. I started it with the amp off and it stopped the only thing that came on was the lock light so then i shut it off, it didn't remain running like it had been and I restarted. after i restarted it was fine. After few hours and a few short trips here and there I replaced the remote wire for the amp and have been jamming to some tunes all day with out a hitch... so i ask WTF? poltergeist?
I am charging my cam now and putting it in the car so if it happens this time i get a funny vid from it.
while it was happening i was saying to myself "holy shit the guys are not going to believe this shit!".
---------- Post added at 07:41 PM ---------- Previous post was at 07:40 PM ----------
maybe your subs are haunted
most logical of logics
M-Town,AZ
For some reason your Amp is backfeeding into the fuse block and fuckin shit up,run your remote wire to something else like the sunroof.
M-Town,AZ
its possible that the amp is backfeeding into the fuse block keeping it powered up after you turn it off until the capacitors run out of juice.My s-10 did that.just have to move your remote wire to something like the sunroof or something
Or you could run a diode to eliminate the backfeed all together and not have to find a new place to find power. Diodes only allow power to travel one way thereby eliminating the problem you're having. I did this to my 1st gen projectors so I had both sets of bulbs on with high, but only the lows for low.
glenn Matayoshi
