Headlight Condensation
Tasana
Still the new guy.
I bought a 2009 Chevy Cobalt 46k and only one previous owner. 2 Door.
The drivers side head light is giving me issues.
It has condensation inside the plastic casing. Water is NOT leaking in, it can be 98 for weeks and there is water droplets inside the light casing.
I have looked it over and can't find a seal leak and since it has water droplets even on bright sunny days I can't understand where the moisture is coming from. The passenger head light is perfectly OK.
Any ideas?
Thanks
Gregory
Sounds like the headlamp needs to dry out. You can do that by pulling the bulb out of the headlight and leaving it in the sun.
bluebaltz
a lot of us have had that issue. i got so much water in mine, that i actually poured it out of one of the light plug holes haha!
anyway, when i took it out, i added some rtv on the seam all the way across the top.
didn't really help lol
Put some butyl around the seal. The window butyl. Its black. Should seal up your light. Its a leak and most likely in the bottom joint where its common
Think that's what I used for mine. Afterwards you need to dry them out inside by leaving the bulbs out and the housing in the sun or heat for a while.
bluebaltz
yes, that's how i got the moisture out, but NEXT time lol i'll get the black butyl & go all the way around
Tasana
Thanks for all the great responses. We got 3 days coming without rain and I intend to do some work on the car, I will follow the advice given and let you know how it turns out. It may be a few days before I see results however.
Thanks everyone.
Your welcome. Update us when done
Tasana
Results with issues
Got the water out here is what I did.
Removed the headlight assembly which was very easy.
Took into house and put a small cloth inside while leaving the tip hanging out of the hole. Using a butter knife I pushed the other tip of the cloth to the front of the lamp and tipped it upside to allow the cloth to soak up the water. Soaked up about 1/4th of the cloth. Then took my wifes hair dryer and aimed it in the holes for some time. Then left it face up in the 95 degree sun. Dried it up nicly.
Now the issue, in my removing of the assembly I discovered the entire wire harness sas croaded from the water. One connector, blinker, will no longer transfer power, I did troubleshoot and try new blubs. I have been looking for hours and can't find just the wire harness. If anyone knows where please assist. I have searched the main auction site.
Thanks.
I got some spare wiring harness at home. I'll snap a pic of the harness I have at home. They have the bulbs for blinker. The blue connector for the headlight halogen bulb. And the small light bulb for reflector. All that with the main black connector to connect to the actual engine bay harness. Is that what your looking for?
Tasana
Yes that is exactally what I need. Is it ok to buy it from you via the forum. If so how much do you want + shipping? I can pay via PayPal. I am driving without a left front blinker. The corrosion on the harness from the water being in there so long is bad. The other day I got a check eng light and when I got the code readr on it it was an electrical error. I forget which, but reset and not came back since I cleaned and removed the offending bulb.
But please tell me how to convay my mailing address and I will.
Thanks.
Uhm. I can send it to ya for 20$? I'll try to send you 2 of them . I forgot the take a picture. I am positive its the headlight harness you need.
---------- Post added at 06:40 PM ---------- Previous post was at 06:39 PM ----------
I'll message you my PayPal and telephone number. For more reference of business. Yelloeye can confirm I have positive feedback on CSS. I sell lots of things lol.
---------- Post added at 06:47 PM ---------- Previous post was at 06:40 PM ----------
These I am assuming u need.
Yeah. I have on my retros lol. Just gonna yank em out and send those. Since I know 100000000% sure they work lol.
jonny_b
any other set of those lying around? i need one for my passenger side. cough cough........lol
OK Tasana should get the pair I sent him.
And yes I have 2 left on my retros lol.
Holy crap. Tasana got the wiring harnesses. For some reason USPS shippers stole both harneses. Wtf!!!!
He got the box opened. Harnesses were removed from box. I filed a claim with USPS. They literally opened it.
