problem with alarm
Godik1985
Belarus
I understand you correctly?
If the problem is in the buttons that I should just replace them. But what if the problem is in the chip. Can I buy a keyless entirely? And then how to set it up under my cobalt?
You can buy a while new remote if needed. But you will need it to be reprogrammed at a dealership or mechanic with a Tech 2 machine.
You can test your current remote by opening it up and using a paperclip to bridge the lock circuit. That will tell you if it is just the buttons.
Godik1985
Belarus
I understand you correctly? If the problem is in the buttons that I should just replace them. But what if the problem is in the chip. Can I buy a keyless entirely? And then how to set it up under my cobalt?
---------- Post added at 10:16 PM ---------- Previous post was at 10:09 PM ----------
I tried connecting the contacts does not help. So I think that the problem is in the chip.Could you show a link to Ebay where there are keychain with a chip?
Is the battery clip still attached? Mine broke and I has to solder it back on.
glenn Matayoshi
