Turbo 2.2 using other factory kits
2003+ Saab 9-3 set up:
-Saab 9-3 turbo manifold
-2003+ Saab turbocharger(both low and high pressure turbo will work)
-turbocharger oil/water lines(inc. banjo bolts)
-Saab turbocharger cold charge piping(for going under the engine)
-universal intercooler kit
-universal intercooler(28"x6"x2.5" fits perfectly behind out bumpers)
-custom downpipe
-42lbs injectors
-injector harness(repin to stock)
-trifecta tune(all years), Ls2edit(07+)
-MAF pipe(i recommend buying a bung from OTTP and having it welded on your piping or call ZZP and have them make u a MAF pipe)
-custom intake or run a mesh filter
-gaskets for turbo, manifold, and downpipe
-wideband kit
optional/recommended:
-aftermarket blow off valve(the turbo has a built in one)
-2.5" catback exhaust
-PnP turbine housing
-high pressure turbo from the b207r saab engine
-2.4 intake manifold/Saab 9-3 intake manifold
-LNF intake manifold strongly recommended
***sensor placement***
-MAF: goes after the intercooler, before the throttle body, keep 6-12" from throttle body
-Blow off valve: after the turbo, before the intercooler
LNF Cobalt turbo set up:
-turbo manifold
-turbocharger
-oil/water lines
-o2 housing
-LNF intake
-downpipe
-hot charge pipes
-intercooler
-custom cold charge piping
-60lbs injectors(may be able to pull of 42's, but better safe than sorry)
-all exhaust gaskets for the LNF turbo manifold, turbo, o2housing, and downpipe
-wideband kit
-aftermarket charge piping W/bov flange on hot pipes, MAF bung on cold)
-aftermarket downpipe
-aftermarket intercooler
-3" catback exhaust
-aftermarket intake(W/NO maf BUNG)
-aftermarket intake manifold
Oil feed line=blue
Oil drain=red
added more pics...and will ad more when i get home, i have a pic of the LNF parts off a car saved on my machine from when someone over on .net was selling it
the saab setup would probably run you in the area of 1000-1500 depending where you have your downpipe made, and on who does your tuning...the lnf kit could be more pricy since those are newer parts not commonly found at junkyards
RJSLSECOTEC
yelm, wa
i think if u search hard enough and have the resources it might be able to be done under a grand.. well thats what im shootin for..haha.
does anyone know what the stock spring is set at on the saab high pressure turbo? like 7psi?? maybe?
06ion2coup
Columbia Mo
under a grand...? are you taking into account the tune, custum DP, Wideband, injectors, pillar pod, there is NO way you can boost a car for under one grand... a decent boost setup will take about 3grand to be running on the car...
ßlåçk§mókè
Saskatoon SK Canada
Not sure about that.... but I boosted a old 92 sunbird 3.1 L for 750$'s
Using all junk yard parts
But if your talking a good strong reliable kit... your looking at 1500 - 2200
Counts what you got for parts already and know the right people
06ion2coup
Columbia Mo
... what kind of gains are you expecting... if im boosting a 2.2 im hoping to go from the 125ish whp to 210 with the power to make over 300
austin, tx
you know you can draw oil from the head as well right? its alot easier then doin it from the block
theres a reason you don't want to draw oil from the head.
there is a restrictor up there.
to be honest the best place to draw oil from is directly from the pan.
---------- Post added at 12:29 PM ---------- Previous post was at 12:25 PM ----------
downpipe = 80 bucks tops, for me 40.
injectors = 150 used with harness.
i bought 60s for 40 bucks before on ss.net.
pillar pod not really needed = 40 used
wideband = 150 used
tune = 200
plus the turbo parts which is on sale on ss.net for 800 right now.
http://www.css.net/forums/showthread.php?t=193961
seriously includes everything you need.even piping and fmic.
so yes it can be had for less than 3k.
---------- Post added at 12:30 PM ---------- Previous post was at 12:29 PM ----------
Have you finished the install?
he did an ls/sc build not turbo.
just giving out info to the site :)
BlackCobalt707
Dover AFB, Delaware
seriously???? how do i remove the restrictor?
---------- Post added at 12:35 PM ---------- Previous post was at 12:33 PM ----------
and how would you draw oil from the oil pan? a pump? and when did they start using a restrictor, i got a head off of a cavy not a cobalt on it
