What's the difference between a lt and rs suspension?
Eventually it could. Get rotated transmission mounts from Powell to fix that.
jonny_b
do they have those for the 2.2? i thought it was only the turbo ss. with a new axle, it should last a while. the bind is only a BIG problem if you are dragging on flatland.
and speaking of axles, i want to try these. they aren't much more than stock, and are supposedly stronger. i think my passenger side one is starting to go.
http://shop.zzperformance.com/store/p/1050-ZZP-2-2L-2-4L-Stage-1-Axles.aspx
Jaws4God
Do you have more details on this? Am I able to do this with basic tools?
Sent from my SGH-M919 using Tapatalk 2
jonny_b
you can do it with basic tools and a floor jack to support the trans. a torque wrench is handy like it is for everything else.
Jaws4God
Is there a how to somewhere?
jonny_b
idk about a how-to, but i have seen a thread or 2 about it. basically you just raise the jack until it is against the trans, remove one of the tranny mount. 3 bolts i believe, and attach the new one. may need to raise or lower the jack a hair to line up the holes to get the bolt back through. search out a trans mount online and you'll see there isn't much to it. its easier than doing the suspension swap you did imho.
Jaws4God
Where can you buy those mounts at? How much are they?
jonny_b
idk. the only 2.2 trans mounts i have seen are just the poly inserts. i thought they only made rotated mounts for the 2.0 ss.
