i bet its the fuel, you started and were able to run fine on what was in there, but it died when it ran out. did you remove the fuel pump relay during install...and then when you put it back put it in the wrong spot (steve and I
) that was a dousy to figure out
we were worried
anywho haha, check that, turn the car to the on position and see if you hear your fuel pump priming, that could be whats causing it. check to make sure your injectors are spitting (take the fuel rail out, hold it to a towel, and try to turn it over, if you get gas out your good on fuel. then check spark plugs and wiring to that, if no spark, no fire. if that is good, then make sure that your not throwing any codes (since it isnt turning on you wont till unless you plug in and check).
after that all...come back and report
---------- Post added at 12:26 PM ---------- Previous post was at 12:26 PM ----------
also, did you rewire the tb and the injector harness for new stuff? cause if not it may be electrical stuffs
