An Idea
yes that is true maybe if someone created a mock up computer program that could actually tell us if something like that would work.
however this would be monstrous task in the making. nothing would line up. i would think about dropping a more powerful 4 cylinder from a heavier car model along with the appropriate harnesses pcm,ecu,bcm etc transmissions and whatnot .. maybe a NSRT engine into the cabalt, i think it would be lighter in weight but the cobalt would then have a better suited engine platform to work on higher hp numbers
camopaint0707
NY
why not just go all out and get the G8 engine and install it then turbo and supercharge it, I can just imagine the tuning problems for that would be crazy
Aredtear
Spruce Grove Alberta Canada
DREAM WRECKERS ALL OF YOU!!!!! hahaha. I dunno what I'll do. Like I said this is about 3 years down the road here (and by then I'll have my skyline) So yeah. But I would have to see the measurements of the engine bay of a g6 compared to a g5. I'm sure their is a way to do this and it would be purdy awesome to be one of the only people who has done it ( I like being unique).
As for that cobalt guy, he ran into lots of trouble with shops and stuff. So that might not be a good comparison.
USMCFieldMP
Findlay, Ohio
I'm not sure, but more than likely, yes. I don't know the bolt pattern on the Trans that they put into the Pontiacs, but it is basically the same as they put in the Turbo Saabs... which is basically the same motor as the LSJ.
You're gonna run into problems with mounts, fitting it (honestly... our engine bays tight enough, as is), and then having custom made axles.
lovely09
A great idea to think and nothing is impossible i guess.If anyone can make it much better for us to see the result but i think there would be some sort of problems with fitting other parts.
pitsnipe
Hampton Roads, VA
finaly a palce where there are people just as disturbed as i am! i came up with the same idea about putting a Grand Vitara H25A 2.5L DOHC V6 in my Forenza, but i got rid of the Forenza before i could even think of planning the swap. it would be very expencive and labor intencive, but with a ton of custom work and some modifing it could work. won't be easy, but it would work and it would be a show stopper
Aredtear
Oh wow.... a northstar V8 in a cavi..... I think the engine bay in the cobalt and g5's are a bit bigger. But that 3800 turbo charged cavi makes me real horny........ DAMMIT I WANNA DO THIS SO BAD!!!
the g6 is a delta body. drop your g5 cradle, raise your g6 cradle. bolt it in and wham-o. only thing is getting a manal tranny bolted up. you guys know they make the cadillac srx with a 2.8 turbo v6 now?
took this pic at work. yes, it is trans mounted for fwd. and yes, it's bolted to an awd drivetrain. have fun.
8balt
