mrsilent13
It's slightly confuddling but the last 2 paragraphs tell you exactly how to time it. Minus the chain tensioner.....
TOM!!! Fix it....![]()
i did my timing with these instructions the first time...since then ive done the timing on these engines a few times where i dont even need the instructions anymore...i also figuered out a way to do the timing without removing the front cover...but its a bit tricky because you need to mark the chain and the cam gears and make sure you put them back exactly the way you pulled them off...or else you will bend something
