Powered By LE5's build thread
PoweredByLE5
SI,NYC
Well everyone keeps saying I should make one. I guess here it is then. But idk it seems kinda pointless since my car is almost done anyway but whatever.
So here's my mods list currently http://img11.imageshack.us/img11/435/modsm.jpg
Here's pics: http://www.cardomain.com/ride/3022946
Here's me racing but don't laugh it was my first time and i think the wheel hop killed my time I'm not happy with the time I got and I know I deff could of gotten better
http://www.youtube.com/watch?v=iAym-2r2hl8
And here's a video giving a tour of my cobalt: http://www.youtube.com/watch?v=i08cukw8-E0
Here's a list of what I need to complete my car.
Interior:
Black door sills front, middle bottom pillars, and rear sills
Black trunk deck lid interior side
Black carpet
Black seat frames
Recover door inserts blue
Front speakers
Amp(s)
Light up my cobalt door sill plates blue with tape light like on a lexus or mustang
Brakes:
R1concepts slotted rotors
Hawk HPS brake pads
Engine:
OTTP stage 1 rotated trans mount
Updates:
Now have 5 gauges. water temp, oil pressure, volts, boost, and wideband.
VIDEO: http://www.youtube.com/watch?v=jpBmne7bZOY
Update 5/7/10
Got my exhaust on! Magnaflow muffler, and resonator. Here's a pic and teaser vid for now till I get a better vid with my HD camera. If you skip to 30 sec in the vid, I close most of the windows so u don't hear all the wind. And I will get a picture under the car as well. I didn't take one when it was on the lift, cause the picture wouldn't of came out good from my phone since I don't have flash.
Video: http://www.youtube.com/watch?v=hTDbJazIgNk watch in HD!
WOT runs: http://www.youtube.com/watch_private...tWaDXcnsOpA60w
camopaint0707
NY
like this should be once you already got the parts shouldn't it?
no a build thread is used to keep track of a build, like mine, updated as parts become available. it is my hope that any questions that eric has can be resolved in one thread, were he can come back to it later if he forgets something
---------- Post added at 09:11 PM ---------- Previous post was at 09:10 PM ----------
but if you want the supercharge parts lists:
First off here is a list of the parts i am collecting
GM Parts
11900248 – LSJ TB To SC Bolts (4)
12575463 – LSJ TB Gasket
12584342 – LSJ Supercharger Gasket
12594387 – LSJ IC Pump Insulator
12597855 – LSJ Intake Manifold Gasket
12597993 – LSJ Stage 2 Serpentine Belt
12614973 – LSJ 1 Bar Map Sensor
15247280 – LSJ Upper Radiator Hose-cobalt addiction chrome URH
9230949 – LSJ Exhaust Manifold Gasket
11516342 – LSJ Intake Manifold Mount To Block Bolts (2)
11589214 – LSJ Supercharger to Intake Manifold Bolts (4)
12345982 – Genuine GM Supercharger Oil (Qty 2) 4 oz ea)
12584369 – LSJ TB To Purge Solenoid Tube
12585150 – LSJ IC Pump Rear Bracket To Intake Manifold Mount
12586367 – LSJ IC Pump Front Bracket To Rear Bracket
12586632 – LSJ Lower Intake Manifold Mount
15226536 – LAP | L61 | L65 Coolant Reservoir
15075118 – LAP | L61 | L65 Coolant Reservoir Cap
15231157 – LSJ Downpipe To Cat Back Gasket
15235773 – LSJ Exhaust Manifold To Downpipe Gasket
15253932 – LSJ Power Brake Booster Vacuum Hose
22729469 – LSJ Windshield Washer Container
22732432 – LSJ Wiper Cowl To Washer Container Hose
88986255 – LSJ 8 Pin TB Connector (LAP | L61 Only 6)
89046833 – IC Pump Connector
90537953 – LSJ Exhaust Manifold Heat Shield
15411879 – 2005 Cavalier Injector Wiring Harness. No cutting needed using GM Stage 2 Injectors
New Parts
ZZP Triple Gauge Pod
OTTP SS SC Pulley Bolts
Aeroforce Interceptor Gauge
GlowShift Vacuum | Boost Gauge
AEM Wideband Air | Fuel Ratio Gauge
OTTP 3.0 Polished Pulley (For Stage 2 Hub)
NGK Copper Spark Plugs (Part# LFR6A-11)
Used Parts
Eaton M62 Supercharger
GM Stage 2 Injectors (42lbs)
Stock LSJ Tensioner
Stock LSJ Downpipe
Stock LSJ Idler Pulley
Stock LSJ Throttle Body
Stock LSJ Serpentine Belt
Stock LSJ Intake Manifold
Stock LSJ Exhaust Manifold
Stock LSJ Alternator Bracket
Stock LSJ Supercharger Pulley
Stock LSJ Heat Exchanger
Stock LSJ Intercooler Pump
how about a intake manifold lower mount???-got it
Standard Bolts Needed (Not GM)
LSJ 1 Bar MAP To Intake Manifold
M6 x 1.0 x 25 (Qty 1)
LSJ Intake Manifold Mount Bracket To Intake Manifold
M10 X 1.50 x 50 (Qty 1)
LSJ Rear IC Pump Bracket To Intake Manifold Mount
M8 X 1.25 X 25 – (Qty 2)
LSJ Front IC Pump Bracket To Rear IC Pump Bracket
M8 X 1.25 X 35 – (Qty 2)
LSJ Idler Pulley To Block
M10 X 1.50 x 75 (Qty 1)
LSJ Idler Pulley To Alternator Bracket
M8 x 1.25 x 25
LSJ Intake Manifold To Block
M6 x 1.0 X 75 (Qty 2)
LSJ Alternator Bracket To Block
M8 X 1.25 X 130 (Qty 3)
LSJ SC Bypass Valve To SC
M8 X 1.25 X 20 (Qty 2)
LSJ Tensioner Lower To Alternator Bracket
M8 x 1.25 x 35
LSJ Tensioner Upper To Alternator Bracket
M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
LSJ SC Reservoir Bracket To SC
M6 x 1.0 x 15 (Qty 2)
LSJ SC Reservoir To SC Reservoir Bracket
PoweredByLE5
SI,NYC
You sold me a downpipe with a leak in the flexpipe. I poop on your build.
um ok i didn't even know it had a leak
well keep it there for a reference there are things about the ZZP kit i dont like
1.) you cant pick the parts yourself
2.) doesnt include a tune
3.) overpriced
yeah but i gotta get it tuned by vince anyway so it doesnt matter and its a lot easier to just buy their kit than to try to piece 1 together
camopaint0707
NY
not really, their kit is 2000 right? I need to buy the coolant and windshield fluid tanks and I'm at $1200 plus the $200 tune. That is less than $1500. So hell with the ZZP kit
exactly, ZZP kit is good for those with money to burn and want it done quickly, but taking your time, getting parts that are low mileage and in good condition will go farther
PoweredByLE5
SI,NYC
you have the option of buying ur own sc and intake mani and intercooler and they will take off some $ but then you have to put their custom pulley on
Robinson
San Diego
there is an m62 kit on ion forums that im very close to complete for like 800 or so.
there's an m62...that you put on an lsj...if the existing one is broken. if it's not an lsj or lnf you have more work to do tham stage 5000 kit from zzp unless you want your car having big problems very soon. or you could just let it sit in the garage and brag about it on forums like most cockbags do. it'll never blow up if you never drive it.
